annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
donnees
rankok
Besoin d'aide.
J’apprécierais l'aide pour la configuration du réseau mobile sur mon LG3-D852. Je ne peux pas changer la période de l'utilisation, aussi.   Merci.
8 RÉPONSES 8
davgendron
@rankok
Bonjour,
Que voulez-vous dire? Avez-vous créé un compte et activé une ligne Public Mobile? Vous voulez de l'aide pour savoir comment utiliser les données cellulaires?
@rankok
LG phones are known to need a factory reset to enable data with a new provider. Try a network reset first .... if that doesn't work back up your data and perform the factory rese
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. Back up data on the internal memory.
  2. From any home screen, tap Apps > Settings .
  3. If using Tab view, select the General tab.
  4. Tap Backup & reset .
  5. Select or clear the following checkboxes:
    • Back up my data
    • Automatic restore
  6. Tap Backup account and follow the steps to create Google backup account, if necessary.
  7. Tap Factory data reset . Alternatively, you may tap Network settings reset to just reset Wi-Fi, mobile data, and Bluetooth settings.
  8. Review the warning message and select or clear Erase SD card .
  9. Tap Reset phone > Next .
  10. Tap Delete all > OK .
Reset network settings
Resetting network settings resets all data connections back to the out of the box factory defaults. The following changes occur when you reset network settings.
  • Stored Wi-Fi networks are deleted .
  • Stored tethered connections are deleted .
  • Paired Bluetooth devices are deleted .
  • Background data sync settings are turned on .
  • Data restrictive settings in applications that were manually turned on / off are reset to the default setting.
  • Network selection mode is set to automatic .
  • Preferred mobile network type is set to best .
The device connections status default to the following when the device is powered on for the first time.
  • Airplane mode: OFF
  • Bluetooth: OFF
  • Data roaming: OFF
  • Mobile hotspot: OFF
  • VPN: OFF
  • Mobile data: ON
  • Wi-Fi: ON
To perform a Network reset, follow these steps.
  1. From any home screen, tap Apps > Settings .
rankok
  1.
  2.
Back up my data
Automatic restore
  1.
  2.
  1.
  2.
Airplane mode: OFF
Bluetooth: OFF
Data roaming: OFF
Mobile hotspot: OFF
VPN: OFF
Mobile data: ON
Wi-Fi: ON
  1.
  2. If using Tab view, select the General tab> Backup & reset .
  3. Tap Network settings reset > RESET SETTINGS > Reset Settings .
rankok
Thank you for responding. I'll try first and second option if necessary.
rankok
Merci d'avoir répondu a ma demande.J'ai reçu des instructions en anglais et je croix que ca va marcher. Si non, je vais vous revenir.
@rankok
That's awesome. I accidently duplicated the instructions but for some reason I cannot edit my posts on the french side. If you have trouble just ask for more guidance....good luck!
martial422
rankok
Thank you; that works.
content que tout fonctionne .. profitez-en
