wrong imei number
tongzhenghuan
Hi, when I trasfer my number to Public.
I was told by text that the IMEI number is not correct, and my tranfer could not be completed.
Now how can I re-intiative the transfer process?
Thanks.
CSA_PM
Customer Support Agent
Hi
I sent you a private message to your created ticket.
@tongzhenghuan
It seems all days there are issues porting from Fizz. It was related to the account number and 0000 in front of the account number.
tongzhenghuan
thank you all.
i was transferring my fizz and their account number looks weird (does not have the correct digit). That's y I used IMEI number.
@tongzhenghuan
You need the assistance from a CS_Agent to help you complete the porting of your number.
I would suggest you have the account number from your previous carrier rather than the IMEI for a smoother porting.
slusagm
better to use account number
there is a porting assistance team you can call and update them with account number  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
 And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
