will my phone work in Saint John City in New Brunswick
Prakashshukla
Hi,
I have the $15/m plan and my home province is Ontario. Will my phone work in Saint John City in New Brunswick or do I have to take an ad on feature?
darlicious
@Prakashshukla
Your plan works everywhere in Canada that is shown on the coverage map give or take geographic topography like hiking in the mountains in bc. If by chance you have the briefly introduced from last spring provincial calling $15 plan then you would need the $5/500min add on to call out of the province you are physically located in....otherwise you are good to go.
Edit: Coverage map...
https://www.publicmobile.ca/en/on/coverage
@Prakashshukla
Your plan should work in New Brunswick because PM is 100 minute outgoing Canada wide and unlimited incoming calls and unlimited texting.
Meow
If you have $15 Canada wide plan, it Should work!
Check your plan's details. At one point of time PM has $15 Province wide plan only. If youhave Province wide plan just schedule plan change on next renewal to the same $15 Plan as it is now Canada wide.
If you see this, you should be OK
