why does checking your voicemai a charge on outgoing
dboxtvinfo715
also how do we stop from receiving voicemail i do not want voicemail how to de activate info please
its 2 monthe i do not check messages, why should i use my minutes
1 ACCEPTED SOLUTION
Accepted Solutions
HALIMACS
@dboxtvinfo715
To "disable" voicemail, dial   *004*8080000000#
To reset it back to defaults, dial   ##004#
46 REPLIES 46
@dboxtvinfo715
https://www.publicmobile.ca/en/bc/get-help/articles/add-an-extended-absence-greeting
NOTE: checking your voicemail from your own Public Mobile device will use your Outgoing minutes if you are on the $15 plan.
BUT, if you call your phone number from a landline or different device to check voicemail - THIS WILL NOT DEDUCT your minutes.
villellamcmeans
@dboxtvinfo715 :It charges outgoing minutes because you have to dial out to it to access the voicemail service. If you don't want to use your outgoing minutes you can use another phone to call your voice mail service or use Fongo app which will use either mobile data or wifi to make the outgoing call.
would this help?
To Disable Your Voicemail, Follow These Steps:
  1. Dial into your voicemail by holding the number 1 on your dial pad.
  2. Select option 3 to “Manage your greetings”
  3. Select option 4 to “Manage your Extended Absence Greeting”
  • Select Option 2 to record an extended absence greeting if you don’t already have one.
  1. If you have an extended absence greeting recorded, Select option 4 to turn on Extended Absence Greeting
  2. Select option 5 to block callers from leaving a message after hearing the Extended Absence Greeting
z10user4
You don't have to. You can continue ignoring it. When it gets to 10 messages then it stops taking new messages. Then after 10 days the first one will delete and allow one more.
Or do as previously suggested.
RosieR
Hi @dboxtvinfo715 I also do not check my messages often.  I use my mobile phone mostly for texting.  If you are a tad curious on who left you messages without using your minutes, use a landline to listen to your messages and/or delete.  Dial your 10-digit number until the voicemail picks up, then press " * "(star)  and then press 1 to listen to your messages.
If you have any further questions, we are here to help.
Cheers
RosieR
kselmak
@dboxtvinfo715
All limited minutes plans use minutes when dialing into voicemail, with every provider i have ever been with.
If you don't want voicemail to pickup at all you could set forwarding of missed/busy/ignored/unreachable calls to a USA number and forward will fail.
If you still want the greeting and letting people know they called the right person you can do above suggested extended getting with disabling having the message.
If you still want your voicemail but don't want to waste your minutes you have two options. The first one is to call in the VM number from a landline, it's a bit long. Second one is to use free Fongo number in your forwarding settings and set Fongo to ring only once, after you miss call it will be forwarded to your Fongo number which can email you the voicemail, you can dial in for free (using data/WiFi) or just click on the play button in vm section in the app.
I also use Fongo to turn my 15 plan into unlined, i turn al my outgoing calls into incoming using only about 0.07 megs of data (most of the time free wifi actually)
HALIMACS
@dboxtvinfo715
dboxtvinfo715
wow bthanks success
@kselmak wrote:
@dboxtvinfo715
Could you please explain? I did not get it...
