09-15-2022 12:35 PM - last edited on 09-15-2022 01:24 PM by computergeek541
Good Day everyone,
Where can I get a SIM card to buy, I am in Brampton, ON. Amazon is out of stock and it seems as there is some delivery problem purchasing online.
Thanks
09-16-2022 05:51 AM
https://www.publicmobile.ca/en/on/store-locator go to this link. Enter your address, city or postal code and it will pop up a map to show you your options.
09-15-2022 01:08 PM
Good to know.. I didn't know that.. it's been awhile since I had bought mine. Thank you!
09-15-2022 01:08 PM
HI @kltt only corporate Telus or Koodo store has it
Use this to find a store close to you
https://publicmobile.ca/en/on/store-locator
call them first, as not everyone has it
09-15-2022 12:59 PM
@jen424atienza- Welcome to the Community. Great of you to jump in and start helping out. So you know, Walmart no longer sells or activates Public Mobile. No retailers do anymore.
09-15-2022 12:51 PM
You can try Walmart at the mobile kiosk, that is where I bought mine.
Hope this helps!
09-15-2022 12:37 PM
Click the find a store link on the bottom of this page. Corporate Telus and Koodo stores should stock them. Call ahead. Many retailers have large Telus and Koodo signs but they aren't corporate stores.
09-15-2022 12:36 PM
@kltt , try a local Koodo or Telus store.
