12-24-2019 01:23 PM - edited 01-05-2022 08:41 AM
12-26-2019 02:12 PM
Thank You
12-26-2019 02:02 PM
@penstar wrote:Are you saying I can use my same SIM card I use now through Koodo?
Nope. Your phone will work on Public Mobile network, but you'd need to buy and activate a PM sim card with a plan. You Koodo sim will not work on PM network.
12-26-2019 01:58 PM
12-24-2019 02:28 PM
@penstar As mentioned by GR you'll receive $10 if you use a friend's referral code and after you've activated your account, you can refer a friend and receive the limited time promo $20 bonus
12-24-2019 01:50 PM
You will need to keep your Koodo account open during the porting process.
Here is more info.
https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
12-24-2019 01:41 PM - edited 12-24-2019 01:43 PM
Well you need to get a PM sim card. Don't cancel your Koodo account. It will compicate things. Do it after you are set up with PM.
It also depends if you are on Koodo prepay or post pay.
If you are on the post pay, you can port your # right away by youself if you are doing it online. 15 mins I was up and running.
If it's prepay you will be asked to for a new # and later you can ask Koodo to port your original # to PM .
Any ways you can go to a kiosk in a mall or Walmart they can set you up without any hassels.
Good Luck.
12-24-2019 01:37 PM
@Coolbeanz wrote:Start off by making sure your phone is unlocked from kodo. Then buy a SIM card and once you have the SIM card pick a plan follow the directions online.
@Coolbeanz That's not necessary since a Telus/Koodo phone will always work with Public Mobile (same company)
12-24-2019 01:37 PM
@Coolbeanz @penstar a Koodo phone will work with public mobile and Telus, they're all part of the same company
12-24-2019 01:35 PM
12-24-2019 01:34 PM
To contact Public Mobile for help you have 3 options:
Option 1: Ask Simon for help type your question and follow the prompts.
Option 2: If you are still having a problem then try submitting a ticket directly to the Public Mobile Moderator Team as follows:
Option 3: If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
12-24-2019 01:34 PM
not close to a walmart store
12-24-2019 01:34 PM
12-24-2019 01:32 PM
@penstar go to Walmart if ones near you and they'll take care of everything and they have a free Sim right now and you'll also get your 2nd month free. Use a refferal code and you'll also receive 10$ to use on your 3rd months bill
