waiting for number port
11-02-2019 11:50 PM - edited 01-05-2022 07:50 AM
i was having issues with my number port, then recieved a call from telus to assist and was told she would try it again and call me back if there was a problem it has been a day and a half and still no working phone and no call back. can someone help with this?
Joining Public
11-03-2019 12:42 AM
@LovesToPM wrote:@computergeek541 That's a good point. It's interesting to assume @Atsirkp has no service at all while I am assuming there's only a port issue.
@Atsirkp are you able to call out?
If yes, and the issue is only with incoming texts and incoming calls, then you can call the Telus Porting Centre.
I am going based on the statement of "no working phone". Perhaps Atsirkp can clarify.
11-03-2019 12:15 AM - edited 11-03-2019 12:40 AM
11-03-2019 12:12 AM - edited 11-03-2019 12:27 AM
@Atsirkp wrote:i was having issues with my number port, then recieved a call from telus to assist and was told she would try it again and call me back if there was a problem it has been a day and a half and still no working phone and no call back. can someone help with this?
While the Telus porting centre might be able to help complete the number port for you, they cannot help with the fact that your service isn't working at all. The Public Mobile service is supposed to work for at least outgoing calls, outgoing text messages, and for data before the number porting has completed, or even if it has failed.
The is most likely an activation/provisioning issue. If that's the case, it's likely that you will need to use the method that @ChuckYeah has provided to open a ticket with Public Mobile's moderators.
I would actually suggest against calling the Telus porting centre. Here's why: Since your Public Mobile service isn't working at all now, getting the porting centre to complete the number port is a bad idea. The number would be transfered over to a non-working service. At least now, you should still be able to use your old carrier's service. If the number is ported overr to a non-working Public Mobile service, you will have no working cellular phone service at either carrier.
11-02-2019 11:56 PM - edited 11-03-2019 12:02 AM
Does your Telus SIM still work. If not, send a support ticket and get help from PMs side.
Creating a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
