vpn
05-24-2024 09:41 PM
05-25-2024 03:48 AM
Unfortunately, PM is a 3rd tier carrier which has the basic service so no free VPN.
You will need to subscribe to one or look into one in the App store.
05-25-2024 12:15 AM
@varllok - I used a Gl.iNet router at home if you are trying to connect a VPN server and use the Wireguard app (Fast) or OpenVPN app (Slower). Both work on my device.
ProtonVPN works, should work for all VPN Providers. Maybe look within your device settings to see how it is configured.
05-24-2024 10:17 PM
ok thanks for helping
05-24-2024 10:15 PM - edited 05-24-2024 10:15 PM
personal vpn, is it a VPN you setup locally on your router? you have to login the router and check.
if someone else helped you, you need to check with the person
05-24-2024 10:12 PM
it’s personal
i deleted and rebooted phone but i forgot to keep old setup
05-24-2024 10:09 PM
i do. I did setup multiple one
but is yours an office one? personal? can you delete the VPN profile and re-setup?
05-24-2024 10:07 PM
do you know setup of vpn?
05-24-2024 10:06 PM
i think it was for free with bell plan
05-24-2024 10:01 PM
I wonder if it was part of the Bell package you had. Once you switched, you lost access to that VPN they offered?
Or is this a VPN you purchase on your own? Like NordVPN or something?
If it is a VPN you purchase on your own, then because you came from Bell to PM, I'd consider resetting your network settings and then reboot. See if that helps your VPN work correctly, once again, if this is something you've purchased.
05-24-2024 09:58 PM
05-24-2024 09:56 PM
i don’t have outside vpn it just was on my iphone just slide the button and vpn was working it was with bell but now i slide the button and nothing
05-24-2024 09:52 PM
I have used different VPNs and no problem.
Uninstall the VPN, reinstall and re-setup and it should work
05-24-2024 09:51 PM
public not provide services like vpn?
05-24-2024 09:46 PM
i had vpn when i was at bell
05-24-2024 09:44 PM
Have you tried rebooting your phone? I use a VPN on my phone with no issues. You may need to reach out to your VPN provider.
