voicemail
Mikio
How can I remove voicemail from my public mobile phone plan ?
JL9
Depending on the reason you want to do this the different avenues above will achieve the desired goal
Yummy
No, you cannot disable vmail but use one of the provided options.
I used trick provided by @softech  and so far no more spam calls going to vmail.
Mind you NO calls will end up in vmail if you use these tricks.
@Mikio You cannot remove Voicemail.  It came free with all plans
You can use this trick as a workaround so people cannot leave you voicemail:
dial *004*8080000000#
This will cause all calls to either ring forever or get fast busy at the point they normally would have been diverted to the voicemail system.
if you need to cancel that, just  dial ##004#
ShawnC13
@Mikio, you are not able to remove it from your plan.   But you can setup your voicemail so the caller can't leave a message.
https://www.publicmobile.ca/en/bc/get-help/articles/add-an-extended-absence-greeting
Follow the following flowchart to create an extended absence greeting and not let caller to leave message:
[3]Greetings --> [4]Extended Absence --> [2]Record  (Inform Your caller that you are not taking any message)
[3]Greetings --> [4]Extended Absence --> [5]Message not allowed after greeting
[3]Greetings --> [4]Extended Absence --> [4]Turn On
Found from this thread How to remove voicemail service?
