voicemail
nadezhdatoronto
Dear Team!
why the customers need Voicemail Password? it's absolutely not necessary! to remember different numbers is make using the phone with extra difficulties.
thank you.
9 REPLIES 9
nadezhdatoronto
Thank you!
fdrcamb519
security is important for all of us, just keep it simple. i dont mind passwords, its to keep us safe.
nadezhdatoronto
thanks! I'll try it!
nadezhdatoronto
thanks!
what we read there-
To protect your privacy, we recommend always requiring a password for voicemail access, even if you’re calling from your own phone.
BUT- to protect our privacy we may have password at our phone and  it isn't convenient to have extra password for  listening to voicemail.
@gblackma wrote:
@nadezhdatoronto you can remove the voicemal  password requirement on your phone. Here's a link on how to set up your voicemail. https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
Thank you gblackma, I did not know that.
Right now someone can call your number from another phone, press * at your greeting and then be directed to your voicemail. They would then need to enter a pw to get into it to listen to messages etc.
Call your number from another phone and press * during the greeting message.
nadezhdatoronto
thank you. but if somebody called me at my phone number, who except me can see it.
JoyLuck
@nadezhdatoronto wrote:
Dear Team!
thank you.
Without the pw, someone else can access your voicemail using another phone.
