voicemail
10-11-2023 12:14 PM
Having trouble with my voicemail my telephone just keeps ringing non stop and can't get messages.
Service
10-11-2023 03:40 PM
Do you know if your iphone is using volte? You can verify that by turning off wifi and then making a call and seeing if the top bar indicator changes to 3G or stays on 4G or LTE. If it stays on 4G or LTE then try dialing the code - *67*17785804001# and then call your number from another phone and see what happens.
10-11-2023 12:42 PM
on my way to canceling my service and get a new provider,thanks everyone.
10-11-2023 12:33 PM
Sorry,tried the iphone solution but didn't work.
10-11-2023 12:29 PM
To troubleshoot vmail access, try calling vmail number from another phone (or even your phone) and not just pressing '1' on phone's keypad.
10-11-2023 12:24 PM
@lachayra - have you ever set up voicemail yet? See here for FAQ's: https://www.publicmobile.ca/en/ns/get-help/articles/voicemail-faqs
If this is an all of a sudden thing. Try restarting your phone or perform a reset of the device's network settings.
This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone: To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode. Your iPhone will reset network settings and restart itself.
android: Find and tap Settings > System > Advanced > Reset options > Reset network settings.
10-11-2023 12:23 PM
I'm just having trouble getting messages on my voicemail,I can actually access my mailbox.
10-11-2023 12:17 PM
@lachayra , I assume you mean you are having problems calling voicemail. Normally long press 1 will bring up voicemail. You can try dialing your area code+5804001.
