voice message
missorange
Is that only three voice message to be keep in 3 days for all plan?
@missorange wrote:
Thanks for the reply. How many days it keep up to? anyone knows?
@missorange  It's limited. 10 days. If you want to save the message I suggest recording it and saving it on your phone as an audio file mp3, amr, wav, etc
if you download a free call recorder program, the first time you listen to that voicemail it will be saved in the app forever.
It is 10 days.  This knowledge base article covers everything you ever needed to know about voice mail for this service.  There are other knowledge base articles covering other aspects of the service that are worth looking into also.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-To-Use-Your-Phone-and-Plan-Feature...
missorange
krazykiwi
Hi,
This is right from SIMon the chatbot -"Space to store up to 10 messages (up to 5 mins long each".
Hope this helps.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
NDesai
@missorange  Nope, I am sure you can keep more than 3 voicemails, i believe 10 is the limit.
