voice calling while in usa not working.
10-12-2022 07:49 PM
I am on t mobile network. I can text but voice calling fails after about a minute
Service
10-13-2022 01:16 AM
@cannonman55 wrote:2g didn't work either
In this type of situation, changing the network type settings couldn't be of help. As the 2g network is the only one that can currently provide voice roaming service, you must have already been on it. Otherwise, you would not have been able to use the service to make or receive those phone calls for that first minute before disconnection.
10-12-2022 08:31 PM
10-12-2022 08:29 PM
Mine or my girlfriends talk never worked either in September i got them to refund my money neither of us cold use talk
10-12-2022 08:23 PM
only options are LTE and 3G under voice and data cellular settings. I think we are going to live without voice calling. We do have wifi for wifi telephone calling
10-12-2022 08:16 PM - edited 10-12-2022 08:16 PM
@KarenMiller there might be 2G network there according to
https://www.gsma.com/coverage/#466
You don't really have to change to 2G , iphone should do it for you when you got a voice call or when you make the call
But for testing, you can force it on 2G by:
Select Settings.
Select Mobile Data.
Select Mobile Data Options.
Select Voice & Data.
To enable 2G, select 2G.
* you can change back to 4G after the test
10-12-2022 08:12 PM
Phoenix. Not seeing where I can force 2G on an iPhone
10-12-2022 08:12 PM
@KarenMiller PM use 3G for voice, but also works on T-Mobile's 2G network. Depends on where you are, there might be T-Mobile 2G network in your area. So, keep trying to connect to T-Mobile, if there is a 2G network there, your phone will switch for the voice call
But if there is no 2G and you need voice? there are still workarounds. Download VoIP app like Textnow. It can be used to make and receive calls whenever you have mobile data or Wifi.
10-12-2022 08:10 PM
Yes I know. But people are having success with T-Mobile's still existing 2G GSM network that they let us use. But the coverage is not great. You might be finding that.
10-12-2022 08:10 PM
Where are you in the US? If you force your phone to the 2G network setting do get any signal bars? Try to make a phone call in this setting. Does the call still fail? Toggle airplane mode on/off and try again. This post will give you helpful info on US Roaming add on so you have a better understanding of the voice call issues and give you links to 2G network coverage maps via the T-mobile network.
10-12-2022 08:05 PM
Thats all okay but apparently the networks down here are not compatible with our 3G voice. Saw that on another thread. LTE means the data and text work but not voice
10-12-2022 07:58 PM
Do you see your bars or indicators change when you make a call?
Did you review your payment history? Also click on the little spinner refresh icons lower down to see what the system might think you have.
Images are always helpful to see what you see. Don't show anything private.
10-12-2022 07:56 PM
no. just bought one ten day us talk/text/data. two days ago text and data are fine
10-12-2022 07:54 PM
Did you buy another talk component while one was active? That's a known problem. Review or provide your payment history for the last couple weeks.
