10-13-2022
01:05 AM
10-13-2022
01:22 AM
computergeek541
Hi All
I would like to park my number with Nunberpark, they have tried to submit a request and apparently public mobile sents SMS to my number to confirm however I am a broad and not returning to Canada very soon.
Is there another way to do it
Does Publicmobile have help desk to receive my written consent
Thanks
10-13-2022 01:25 AM - edited 10-13-2022 01:27 AM
If you are porting out of PM then you can't because PM Roaming on works in Canada and USA (with Roaming Add-on).
10-13-2022 01:23 AM
Thanks for the correction...misread the question.
10-13-2022 01:21 AM
@will13am wrote:@Kbaden , generally your acknowledgement of the number port is the security measure to prevent fraud. You could use the chatbot link and submit a support ticket and have a CSA look into doing if for you.
While a Public Mobile can manually approve the port out, you will not be able able to use the normal port out procedure because there isn't any way to receive a text message on your Public Mobile service unless you are in Canada or the United States. You could get a family member do switch your service to a Public Mobile SIM card and have your family member approve the port out by text message.
10-13-2022 01:14 AM
10-13-2022 01:13 AM
@Kbaden , basically my suggestion above is to leverage the last paragraph in this help article.
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
10-13-2022 01:10 AM
It could work if your previous carrier have Roaming where you are located to receive a text confirming you are porting over to PM with the old SIM in your phone. Otherwise, you need to wait to return to Canada.
10-13-2022 01:09 AM
