09-01-2018 06:45 AM - edited 01-05-2022 01:37 AM
im so mad right now i pay you for service and it is 4 days and i still cant get calls coming in i want my money back i will not tell ppl to use you i will tell them to stay far away grr fix this now i shouldnt have to get a **bleep**ing run around to get this fixed
09-01-2018 11:01 AM
@sarahdi wrote:i can text and recieve text and make out going calls but cant recieve calls with the number that i ported
Does your old sim still work or was that unprovisioned?
09-01-2018 09:57 AM
This is a porting related problem that needs moderator team support. Please contact them via private message as already suggested.
09-01-2018 09:54 AM
09-01-2018 07:38 AM
@sarahdi I am assuming you are porting. Most ports fail because of user error in the porting process. Have you messaged the mods with the correct account number and name on account?
They are the only ones who can fix port issues.
Your old sim should work until the port is completed.
To get help:
How can you get help with your account, activation, or service?
In your message please include:
If you have a Porting issue, please also include:
Don't know your pin?--provide any 3 of the following:
How long until they reply?:
Additional Useful Information:
09-01-2018 07:20 AM
@sarahdi wrote:im so mad right now i pay you for service and it is 4 days and i still cant get calls coming in i want my money back i will not tell ppl to use you i will tell them to stay far away grr fix this now i shouldnt have to get a **bleep**ing run around to get this fixed
As soon as it works though, if you use autopay, it will just work afterwards. Porting can always be a nuisance, no matter which carrier you switch to. Just be patient, you'll be happy soon enough. 🙂
