verify
aj15
how should i verify that i am the owner to read my inbox messege
10 REPLIES 10
Moved:
Consistently posting the same message again and again despite the same informatoin being provided more than 12 hours earlier is a form of gaming.
CountyDownIeUk
Do you mean this?
Put in the email you used and save...then respond to email verification.
aj15
thanks
@aj15   You have to reply the message CS agent sent you (the one with the validation link) , tell them what happened and they might validate you via messaging with you instead
aj15
yes i clicked the envelope it had an authentication link which i failed to verify in 4 attempts and now its locked i cant even read my messege from customer service
Outdoorsman
hi if you meen your community inbox (the little envelope top right corner) you just click on it and open the message
aj15
i was using but unfortunately my account is locked
@aj15   Your My Account is locked?  did you try to use Reset Password option there to try reset the password?  Try that first
If still fails, open ticket with PM Support:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@aj15   What do you meant by that?  you are logged on as "aj15" in this Community, the inbox is for "aj15".
If you want to make sure it linked to  your PM My Account properly, please use the same email address on both your Self-Server My Account and the Community here
aj15
