09-28-2022 04:41 PM
09-28-2022 04:50 PM
thanks
09-28-2022 04:48 PM
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
09-28-2022 04:46 PM
Are you a current customer ?
If you ported out a public mobile number to another provider or an account was closed due to 90 days of nonpayment, then you cannot access My Account/Self Serve (once known as). So you'd have to activate a new sim card for a new account with public.
Otherwise, see @softech 's post for help.
09-28-2022 04:44 PM - edited 09-28-2022 04:45 PM
@gittyklein its an email address.
If you forgot, try to use Reset Password link there and enter any email you might have used and check if it gets the password reset email
If that does not work, open ticket with PM support
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-28-2022 04:43 PM
i forgot all my log in details
09-28-2022 04:41 PM
use email id to LOGIN.
