07-07-2022 07:04 PM
I already have this plan for usa roaming. Can I use the 10gb of data in the usa without buying another add on? Will it work straight away or do i need to do something to activate it in the usa?
Plan Details:
07-08-2022 01:33 AM
@MrSpock wrote:@dunccurtis hello you will need a 10 day roaming add on for the US but beware, with all the 3g being shut down stateside you may have nothing but problems like a lot of people lately, if you can get a local sim you may be better off, oh and your plan won't work in the USA sorry
3G shutdown would only affect calls technically... Data roaming should continue without interruption.
07-08-2022 12:02 AM
A lot of people have had issues with the US roaming recently, most reliable and cost effective method would be a local prepaid sim options and/or voip app
07-07-2022 07:23 PM
HI @dunccurtis the plan you got is for use from Canada only
When you are in US, you need US roaming add-in
Data roaming add-on has a 10 days expiry and could be expensive. If you are planning to be there longer than 10 days and expected to use more than 1GB, you will be better off buying local Data prepaid plan
07-07-2022 07:22 PM
Many people confuse the US minutes or international texting as meaning they can use the service elsewhere. You can't. There used to be a plan that had roaming but it was short-lived and well sought after.
So for all other plans, you need the roaming add-ons to use the service in the states. And only the states.
07-07-2022 07:18 PM - edited 07-07-2022 07:19 PM
07-07-2022 07:11 PM
@dunccurtis hi that plan is for calling USA from Canada it is not for use in the states, you will need a 10 day roaming addon
