07-08-2022 12:14 AM - last edited on 07-08-2022 01:30 AM by computergeek541
07-08-2022 01:29 AM
If you have wi-fi access where you are, you can install an app like TextNow or Fongo Mobile which will give you a separate Canadian number with ability to make free calls over VoIP to Canada.
07-08-2022 01:20 AM
Sorry you can't call Canada from UK because there are no Telus cell towers in the UK. You can call UK from Canada on Telus cell tower.
You need to buy a local SIM in the UK to have cell service.
07-08-2022 12:16 AM
No.
Your Public Mobile service only works while in Canada or USA, with a USA add on.
