12-10-2022 01:03 PM
what is the exact amount of the $15 data us add on is it $15 plus HST or is there other fees involved. I have to add the amount to my account so I don't want it to be under that amount thanks
12-10-2022 02:07 PM
Yup Tax on
12-10-2022 01:18 PM
You don't need to pay in first. You select the add-on to put in the cart then pay for it. That will show you all the details and you can get a receipt.
For the add-on, think of buying at the top of an hour. Exactly 240 hours later it will stop.
Only T-Mobile will connect. So either use automatic networks or manually select it.
Turn on data roaming on the phone.
12-10-2022 01:09 PM - edited 12-10-2022 01:15 PM
hi @johnpublic you don't need to add tax to it. Just add $15
When you add $15, PM will add tax in top. So, just put $15, PM will charge you $15+tax on your credit card. You will then see $15 in Available Fund and you can use it to buy $15 addon
12-10-2022 01:06 PM
No other fees but TAX.
12-10-2022 01:04 PM
$15 + tax
