09-17-2025
08:30 PM
09-17-2025
08:54 PM
computergeek541
09-17-2025 09:14 PM
Double check and enter the A50 IMEI to see if it is VoLTE (voice over LTE) at the bottom of the link.
09-17-2025 09:04 PM
Thanks. Eventually I will be upgrading my phone.
09-17-2025 09:01 PM
09-17-2025 08:48 PM
@Sue-s1 your phone does have VoLTE, LtE is short for VoLTE. When you call someone, what's the status in the upper right corner?
It should work fine in Mexico, however you might have issues in the USA because even though it has VoLTE, your phone is not supported by PM. So eventually even here in Canada you will be experiencing voice issues eventually.
With the Canada-US, Mex plan, you don't pay a roaming fee.
