07-22-2021 12:17 PM - edited 01-06-2022 03:02 AM
07-22-2021 12:25 PM
You would be better off to leave the credit which could be used for your next payments.
If you want a refund, there is no guarantee but you could submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
07-22-2021 12:24 PM - edited 07-22-2021 12:24 PM
@Lisa65 when you requested plan change, there was an option to change Immediately or change at the end of the cycle. You might have chose Change Immediately and hence they will charge you the new plan charge at once.
If you notice it charged you twice with the new plan charge, either you have accidentally clicked twice or PM made a mistake. But if you check My Account, any chance the 2nd duplicated charge is there as Available Fund? If so, that Available Fund will be used in the next renewal (one month later). You can leave it there if you want to
Or if you really want duplicated charge refunded, you can contact Mod :
(After you open a ticket with mod, please monitor your Community inbox, envelope on the top right. Mod will communicate with you via messaging within Community)
1. For faster response (2 to 48 hours), Click on the bubble in the lower right corner and request moderator assistance, or you can also use this direct link instead https://publicmobile.ca/chatbot. Start with typing "Submit a ticket", click on "Contact Us", click on "Other" from the choices, click "Click here to submit a ticket" then Follow the prompts to submit a ticket.
2. Or you can Send a private message to the moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-22-2021 12:24 PM
Is the extra charge now in your available funds in your account? its easier to just use it for your next renewal as it takes up to 30 days for a refund. Otherwise contact the moderators.
