04-22-2020 12:47 PM - edited 01-05-2022 11:43 AM
hi - i had trouble paying w credit card (which should work fine - has done many times before) so I removed it in order to re-add - but I cannot even re-add it without an error.
also cannot use at time of checkout:
Unable to Process Transaction
Sorry, we are unable to verify your credit card information, so this purchase could not be completed. Your credit card has not been charged.
Any help appreciated as I expire tomorrow.
Rob
04-22-2020 03:40 PM
Thanks - shall do.
04-22-2020 03:33 PM
@Robert5 wrote:Thanks everyone - but none of this helped.
What more can I do?
I have confirmed the CC is fine.
As I mentioned, it had worked fine for many months.
Confused.
Did you get going with the moderators? It's likely that the card processing is locked due to fraud defense. So all you can do is get the mods to clear things up for you.
04-22-2020 03:29 PM
What more can I do?
Confused.
04-22-2020 01:00 PM
Try using a different browser and incognito mode. Also clear your cache and cookies then reboot and try again.
04-22-2020 12:52 PM - edited 04-22-2020 12:52 PM
Clear your browser cache/history/cookies. Close browser and open a new browser in incognito/private mode. Also, you can try a different browser.
Enter the credit card address Exactly as it appears on your statement.
Leave the apartment field blank. If needed enter your apartment number in the street address field.
Enter your postal code without spaces unless there is a space on the credit card statement then enter the first 5 digits only with the space.
Note: The credit card will get locked after a few failed attempts. You will then have to contact a moderator for assistance to have it unlocked.
04-22-2020 12:49 PM - edited 04-22-2020 12:50 PM
@Robert5 wrote:hi - i had trouble paying w credit card (which should work fine - has done many times before) so I removed it in order to re-add - but I cannot even re-add it without an error.
Rob
If you're having trouble registering or updating your credit card, here are a few tips you can try:
Hope this helps!
