unable to submit a ticket
lane_L
I am unable to submit a ticket, I was porting my number over but I got an error  saying my IMEI number is incorrect, but it is correct. How can I get in touch with someone to fix this?
1 REPLY 1
@lane_L
Did you use IMEI as the porting info? It is better to use account number of your old provider instead.
There is a number to call to talk to live support and you can update them with the account number.  They can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
