08-30-2018 09:44 AM - edited 01-05-2022 05:32 AM
Hi,
am unable to send or download pictures on my phone. I have data enabled? the phone is unlocked? I don't know what else to do?
Please advise.
08-30-2018 12:22 PM
08-30-2018 12:08 PM
@RobertQc I thought no the article you linked to has been deleted.
08-30-2018 11:10 AM - edited 08-30-2018 12:23 PM
@helenehreich wrote:Hi,
Please advise.
You need to configure your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
08-30-2018 10:54 AM
@mimmo wrote:Have you set up your Apn?
Is data on? MMS uses data to send but you do not need a data plan.
This might help setting up your Apn
If you are using an LG phone you might need to do a network settings reset, or factory reset
Also need to enable mobile data.
08-30-2018 09:54 AM - edited 08-30-2018 09:58 AM
