unable to make or receive phone calls
06-23-2022 11:00 AM
I am unable to make or receive phone calls. When people call me they either get "call failed" or it goes directly to my voicemail. My account is in good standing. I have tried rebooting my phone.
Service
06-23-2022 02:44 PM
@michellebanks if none of those suggestions work, open a ticket with PM and have them to confirm if there is any problem with your account or any network issue in our area
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
06-23-2022 02:35 PM
Tried all that but still having problems. Starting to think its a wider issue with Telus as I've just heard from a few other people they've noticed lost calls and poor service for the last few days.
06-23-2022 11:39 AM
AB, SE of Calgary here. Does your account say "Plan expired"? I'm having the same issue and my account says that, despite a payment going through yesterday.
06-23-2022 11:38 AM
Mot likely it is temporary service outage.
You can check it here: https://www.telus.com/en/nt/outages?linktype=ge-footer
06-23-2022 11:10 AM
Im in Alberta, Stony area
06-23-2022 11:09 AM
@mamabear_5 which area you are at?
There were posts earlier this morning about issue in Northern Ontario. But there is no official outage according to Telus page
Try what I suggested above.
On top of those, also try to change your Preferred network to 3G Only and see if it helps
06-23-2022 11:05 AM
Phone was working fine at 7:50 then was unable to make a call. when people call me it goes directly to voicemail. Currently when i try to call it just starts counting for active call but there is no ring, no nothing
06-23-2022 11:03 AM
So, you both checked My Account showing account status : Active?
And on your phone , does it show any error on top like "No Sim", "Sim not provisioned", "No Network"? Dos it show any network bars?
First try to reboot the phone once and test again
If still fail, try to reseat your SIM (power off the phone, remove the sim for a minute before putting everything back and power on), then try outgoing and incoming calls again
If still fail, and you have another phone around, try to put your PM SIM card there
06-23-2022 11:01 AM
me too
