u.s to Canada phone calls
Dalek1999
I have a $34 50 gig Canada  - US plan,
can I make phone calls from u.s to canada  as well.
Ardbeg1954
In order to phone from the US back to Canada, you will have to purchase an add- on
self solution removed
Dalek1999
thanks for that info
Chalupa_Batman
Hey @Dalek1999
I was just in the US a few weeks back and I was able to not only call back home to Canada, I was able to text everyone and even FaceTime with them using my data. It's all part of the plan!!  Just know, when you get across, just go to your network settings and make sure your data roaming is turned on and turn off automatic and join the T-Mobile network and reboot your phone. Enjoy the trip!!
hi @Dalek1999 yes, calling from US back to Canada is included
