trying to port number from rogers
CandaceViolet
ive switched from rogers and ported my number to public mobile its saying everything is fine but i can only receive calls from other public mobile customers and no other cell provider......rogers said everything is fine on their end .............Please help !!!!!!!!!!!!!!!
angeliquem
My best suggestion is that you private message a mod now.
The port could work in the next few hours but at least you would already be in queue with the mods if it still doesn't work after a few hours.
Send a private message to @CS_Agent and provide all the necessary info like name, phone number, account number, pin number, sim card number, rogers account number etc.
mimmo
Does your old sim work if so use that,till port completes (assuming stuck port)
Interesting that pm calls go to the pm sim but others dont
RobertQc
If you just ported, it takes some time, every hour or so remove your battery / restart your phone. It can take time on your first port over and there can be weird issues for a short period of time.
If the issue continues you may have a partially completed port but most often ports just take a bit longer. One of the moderators can take a look, see if they need to do something to move it along.  Click this to send them a message
I know it can be a little frustrating to wait but send a message to the moderator team and include your name, account number and/or phone number and pin number and they will get back to you asoon as they can between Monday-Friday 9am-9pm (EDT) and Satuday-Sunday 9AM-7:30PM (EDT)
For more information about contacting a moderator Click Here
KMG
How long ago did you port over?  It can take a few hours for everything to finalize.
If it has been longer, you should contact the Moderator Team so they can look into it.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/The-Public-Mobile-Moderator-Team/ta-p/...
