trying to cancel add-on
dryammine
How do i cancel an addon? I needed it for a short period and now just want to go back to my regular plan. I only use this number when i am traveling.
I did not find an option, so i just removed the autopay, thinking that will stop it.
But i do not want to lose my number. I need the SIM active end of June.
11 REPLIES 11
darlicious
@dryammine
Were here anytime to answer your questions. If you are in doubt just ask the community. We are always happy to help!
dryammine
yes - it all looks correct. And the answer to clarify that add on do not auto renew was helpful, as is the 90 day rule.
dryammine
thank you.
dryammine
thank you. that answer my questions.
dryammine
thank you. it was a 1GB data add. Thank for explaining the 90 day rule.
darlicious
@dryammine
Can you check your transaction history to ensure that you have only been charged once for the add on and then your plan charges that are listed as follows :
  • 30 DAY PLAN..........................$10
  • 100 MINUTES.........................$5     or
  • 1GB+DATA AT 3G SPEED.......$15+
JL9
When you get a chance, give us a heads up on what add on you are talking about to make sure there is no confusion
iliketotalk
@dryammine @Hi there is no need to cancel an add on it is a one time payment , with the exception of the 10 day us roaming they just stay on your account and get used as needed you will not be charged again
@dryammine what add-on are you talking about?  Autopay will only trigger for plan renewal and it won't auto re-buy your add-on.  All add-ons are one time purchase and are bought manually.
If you meant you want to cancel your service, then disabling Autopay is what you need to do, which you did
But with Autopay disabled, if you don't manually pay,  your account will be suspended at the end of the current cycle and you will loose your number if you don't do anything for 90 days after that
dust2dust
Canadian add-ons stay on the account until finished. You can't just stop using them. Are you meaning roaming? Are you meaning Canada-wide? Roaming add-ons stay on for 10 days.
Removing autopay will stop your plan from renewing. You could let the plan suspend until you need it but only do that for up to maximum 90 days.
@dryammine  addons you purchase in your self serve account or by calling 611 do not reoccur. Once they are all used up they are gone.
Your plan services should always get used first, and the addon will only kick in when plan services run out in a current cycle.
