Activation of SIM card
Parmeeticai
I have activated a sim care with number 20xxxxxxxxxx yesterday morning but it's not working till now. What's the timeline for activation of SIM?
Edit by Dunkman: removed personal information
darlicious
@Parmeeticai
Do you have any services working on your phone? Does public mobile show up? Is your phone older than a 2018 model? It does sound like your "sim card did not provision correctly upon activation". Type that and "human" into SIMon and follow the prompts to submit your ticket via SIMon.
Keep an eye on your private message box the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times but expect a reply within an hour.
@Dunkman
Thanks for the quick editing!
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
@Parmeeticai activating a Public Mobile with a new number is nearly immediate.
If you have activated a new account and transferred over from another provider, note that incoming calls are usually the last to port over.
  • Cell ports can take 2-3 hours. Use the previous provider's SIM card to receive the porting transfer text for approval to port to port over to Public Mobile and to receive calls from until port is complete.
  • Landline/voip ports can take 3+ days. Expect a mix of services on the landline and Public Mobile SIM card until port is complete.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
If you missed the porting approval text or still having issues with a new activation, submit a ticket with Public Mobile representatives (CSA) for help; click this link: to request the transfer of your number over to Public Mobile.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Or, are you a current Public Mobile customer already and you were performing a SIM-Swap on your existing account?
Some networking troubleshooting to try:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone for a few days to see if the issues are the same...this could rule out a device issue/setting.
*is your phone locked to its previous provider?
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
@Parmeeticai   Are you not able to make outgoing number at all?  Is there any error showing on your phone status ?
If you cannot make outgoing calls, it could be a SIM provisioning issue.  It is a quick fix for PM , please open ticket with them:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
iliketotalk
@Activationis almost immediate are you porting a number? anything working on your phone?
iliketotalk
@Parmeeticai please click the down arrow top right of your post and delete personal info you are on a community forum anyone can see your info
