12-02-2019 10:42 PM - edited 01-05-2022 08:16 AM
i have just registered with Public mobile and I needed to create new phone number. I woudl like to use my old numer from koodo provider which is sitll active. How to transfer? I do find lot of info that it is possible and easy to tranfer but not a single time I came accross a link that takes me to actual request. I guess I do not do that through my koodo account??
12-05-2019 07:58 PM
Contac rep
12-03-2019 02:24 AM
thank you very much. I have koodo prepaid and I have created a moderator ticket so lets see what happens
12-03-2019 02:22 AM
i am trying to do it and have filled moderator ticket. Lets see what happens 🙂
12-02-2019 11:34 PM - edited 12-02-2019 11:35 PM
@adomu wrote:i have just registered with Public mobile and I needed to create new phone number. I woudl like to use my old numer from koodo provider which is sitll active. How to transfer? I do find lot of info that it is possible and easy to tranfer but not a single time I came accross a link that takes me to actual request. I guess I do not do that through my koodo account??
For a port from Koodo, always use account number. As others said, the method of porting is different if postpaid or prepaid.
12-02-2019 10:46 PM - edited 12-02-2019 10:46 PM
If you are porting a Koodo postpaid number, use the following:
[Plan and Add-Ons]--> [Change Phone Number] --> [Transfer a wireless or wireline number ]
If you are porting a prepaid Koodo number, Create a moderator support ticket using the ? button at the right side bottom corner of this page.
Keep asking SIMon to "contact rep" for one or more times. SIMon will eventually show you the "Submit a ticket" button. Click on submit button to get the create ticket screen.
12-02-2019 10:44 PM - edited 12-02-2019 10:44 PM
If Koodo prepaid then you will need moderator assistance.
If Koodo postpaid then you can do it yourself under the Change Number option in the self-serve.
