transfer phone number to a new phone
Dana6
Hello
I bought a new iphone and wish to use my phone... not sure to how transfer my number to my new iphone. I believe I have an e-sim currently?
thank you!
@Dana6   See the instructions towards the middle of this page.  You will need to use the app.
https://www.publicmobile.ca/en/ab/get-help/articles/esim-faqs
hI @Dana6
for eSIM, you need to use the app , not the browser
Install the app on the device you want the esim installed
on the app, to go Subscription & Add-ons , click the Buy new sim button at the very bottom and you can buy there.
Dana6
thank you. Not sure how to purchase a new eSim on the PM app. I tried in my account on the desktop and i get the option under AddOns to buy a new eSim. However, when i select it, it sends me to the PM app. In the app however, i don't have the Addons to buy a eSIM? thoughts?
Phil_Adelphus
@Dana6   If you're not sure what kind of sim you have, when did you sign up with Public Mobile?  E-sims are new this year so if it was before they were introduced it would indicate a physical sim card.  As @computergeek541 said, if it's an e-sim they are not transferrable and you'll need to buy a new one. If it is a physical sim card then you just take it out of the old phone and put it in the new one then restart the phone.
You'll need to you go into your Self Serve account and use the change SIM card option.  A new eSIM will need to be purchased.
