09-10-2025
04:06 PM
09-10-2025
10:04 PM
computergeek541
11-17-2025 06:50 PM
@SangheeWoo wrote:I gave them the wrong account number before, so I’m waiting for their call, but they haven’t called yet.
Public Mobile will not call you. You'll need to open a support ticket.
11-17-2025 06:48 PM
09-10-2025 04:31 PM
thanks all good now!
09-10-2025 04:13 PM
But that is not a port issue, your phone or sim not properly setup on that system
Reboot phone and see if it connects
Or ask PM to re-provision the sim. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
09-10-2025 04:12 PM
@Dnell82 any chance you are using e-sim and still have the old carriers sim set to primary?. Does date and texting work and only calls are having issue?
09-10-2025 04:11 PM - edited 09-10-2025 04:13 PM
Couple of things to review.
Did you reply to the sms from your previous provider to verify the port?
Did you remove the previous sim?
Restart your phone to see if that will make any difference.
If none of these work for you ask PM support to check.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
'Contact Us', and choose your topic.
