11-17-2025
04:53 PM
11-17-2025
06:54 PM
computergeek541
I have converted my iPhone after I realized the phone wasn’t compatible at that moment with an eSIM however, now it won’t let me activate
11-17-2025 05:57 PM
The iPhone 14 is eSIM compatible so it should work.
Contact a CS_Agent to help you with the activation.
11-17-2025 05:41 PM
No the covertion is from a sim to esim which allows you to do on my iphone 14
11-17-2025 04:56 PM
eSIM on iPhone works on PM network and no compatibility issue, or are you converting from iPhone to another phone?
And are you existing Public Mobile customer and just changing phone ? or you are new subscriber? g
