03-23-2023 10:42 AM - edited 03-23-2023 10:46 AM
Hello,
My question is to anyone who already has VoLTE profile enabled and using Pixel 3a XL - does it work?
I know that in official FaQ section of Public Mobile it is not listed as VoLTE compatible,
https://www.publicmobile.ca/en/on/get-help/articles/volte
but checking my IMEI number on Telus website it is saying - compatible.
https://www.telus.com/en/support/article/how-to-use-volte
So please report anybody who was able to activate.
In case someone do not know how to check - dial *#*#INFO#*#* and then open Phone Information. You should see VoLTE provisioned toggle in ON (enabled) or OFF (disabled) state...
Thanks.
03-31-2023 11:20 AM
My account has VoLTE according to the SMS received as well as confirmation from a CS agent.
VoLTE does NOT appear as provisioned on my 3a XL. Phone drops to 3G when making calls.
Interestingly, VoLTE shows as enabled and works as expected when using the 3a XL with a Rogers SIM card.
I have an active ticket with support and am awaiting a solution.
03-23-2023 11:08 PM - edited 03-23-2023 11:57 PM
I just tried my sim in an old Pixel 3a and it dropped from LTE to 3G when making a call.
I'm going to upgrade the software to Android 12 after the battery charges up a bit, and then I'll try again.
EDIT: I've updated the software to Android 12, reset the phone, but still it dropped to 3G to make a call. What's interesting is this link states that the Pixel 3a would be updated in June 2022 to allow for VoLTE roaming, but my device says that there are no further updates available beyond May 2022.
03-23-2023 11:23 AM
I have an old 3a at home (not XL) and i have VoLTE enabled on my line. If you like I can swap the sim when i get home and see if it's working. Won't be until tonight though.
03-23-2023 11:18 AM
Also... Depending on your location the difference between 3G and VoLTE might not be as much of a difference that 3G isn't adequate for a few more months.
So you could wait until Public Mobile declares the roll-out as complete. If you don't get VoLTE at that point you could shop for deals on the nex promotions?
03-23-2023 11:17 AM
HI @alexs20 Yes, other than wait and keep checking, nothing much you can do. Even you open ticket, they will just read the same help page you found
but if you have a friend with newer phone, test your sim card there. As long as you confirmed your account is VoLTE, then you can focus on confirming if your Pixel works
03-23-2023 11:09 AM
Checked my current firmware and it is SP2A.220505.008 from Sep 2022... so if xda-devs are right then it should support it. Ok, looks like there is no big choices, but only to wait..
03-23-2023 10:58 AM - edited 03-23-2023 10:59 AM
03-23-2023 10:51 AM - edited 03-23-2023 10:52 AM
The list in the help article is not conclusive. It's essentially the phone line up sold by the Telus group There are multiple reports of phones not on the list that work (mine included).
I remember a note recently that Googles latest upgrade to the 3a / 3a XL included VoLTE capability so that it can be used for calls in the US after the 3G shut down. So if you are on the latest update your phone "should" likely work.
It might simply be that your line / account has not migrated to VoLTE just yet.
03-23-2023 10:49 AM
@alexs20 , according to this information, the 3a xl should work. However, it does suggest carrier specifics. I am going to guess that it could be YMMV with this service.
https://www.xda-developers.com/june-2022-update-pixel-volte-roaming-carriers/
03-23-2023 10:48 AM
HI @alexs20 some senior CS agent said she asked, confirmed that some phone could work on Telus VoLTE and might not work here (I think it was for iPhone 6s)
I still think there is a chance it will work eventually. Right now, they are still setting up, it could work when all are done
And you sure your account is already VoLTE enabled? did you test your sim in a phone there is certainly VoLTE compatible and on the list?
