3 hours ago
I activated my plan yesterday and I selected e-SIM and my phone does not support e-SIM, I got a new physical SIM and I need to transfer my plan to the physical SIM
an hour ago - last edited an hour ago
Simply login to your account ---> click on PROFILE ------> Click on EDIT SIM -------> Input your new Sim number and you are done.
Don't forget to re-boot your phone after you update your SIM card.
3 hours ago
There no set time. I heard some people have had Response as early as 20 min and others had to wait days it all depends on how busy they are.
3 hours ago
Usually within a few hours. Check your private inbox for response.
3 hours ago
@Dunkman Thanks for your answer, do you know how long it will take to get an answer from PM. Thanks
3 hours ago
Are you able to access your self service account? If you are able, then you can change your SIM card number under Profile section.
If unable to access your self service account, then you will need to contact customer service agent:
Send a private message to CSA through the following link :
