texting not working
Rocco2
I have been on the $25 plan
  • 1024 MB at 3G Speed
  • 30-day plan
  • Unlimited Canada-wide Talk
  • Unlimited International Text
I can't send or receive texts anymore on my iPhone. I cannot verify my number on imessages, I've tried restarting my phone and toggling imessages on and off.
Rocco2
Thanks, I tried it but it doesn't work - will see if the CS agent can help.
@Rocco2  If you turn off face time and iMessage , then go to setting general >shut down will be in blue lettering .. wait 5 mins turn phone back on then go turn face time back on and iMessage back on it’s should verify you number again with a check mark .. and you should be good
Rocco2
Thanks, I'm going to try sending a private message to a CS agent
Rocco2
Thanks - I've tried resetting network, and have updated my iPhone to the latest, can receive calls and data is working.
@Rocco2  You may need support to do a reset on your account
Message support directly
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
LitlLdy
@Rocco2 , please reset network settings & reboot your iPhone then try again.
Also, have you updated your iPhone to the latest update 16.5?
Edit: Are you able to call out & receive calls? If your data working?
