06-09-2025
01:19 PM
06-09-2025
04:19 PM
computergeek541
texting new numbers defaults to my old telus account and I can't change it to public mobile
06-09-2025 01:22 PM
hi @garwood
did you move from Telus to PM. Check if your Telus sim card still there and remove it. If Telus' is an eSIM, disable it
Then Reboot phone and Reset Network Settings. Go back and confirm if PM is now the only sim there. Make sure it is set as Primary and Enabled (or turn on this line is toggled)
06-09-2025 01:22 PM
if you successfully activated new Public Mobile account, try a network reset to see if that clears it up.
06-09-2025 01:21 PM - edited 06-09-2025 01:22 PM
@garwood wrote:texting new numbers defaults to my old telus account and I can't change it to public mobile
Hey @garwood
Are you using an iPhone or Android? What phone is it?
If it's an iPhone, do the following.
Go to Settings > Messages>Turn off iMessage.
Go to General > Reset > Reset Network Settings.
Once the iPhone is open.
Go to Settings > Messages>Turn ON iMessage.
This will recognize the new sim and have it verified.
06-09-2025 01:21 PM
you still have the old Telus sim card or esim there. Remove or delete them. Then reboot phone and Reset network settings
