Lost sim
Mb2025
I've lost my Sim card so I can't receive a verification code to log in to my account and order a replacement. What's the solution?
Chalupa_Batman
Hello @Mb2025
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
Or find a Mobile Klinik near you. https://mobileklinik.ca/stores/
Side note, if your phone takes eSIM, that option is available as well.
hi @Mb2025
buy the replacement Public Mobile sim card from Telus or Koodo store for $10 or buy from Amazon for $5
When you have the new sim, you can login My Account buy getting the 2FA code via email.  Just click Didn't receive code and then click Send email
if you really cannot login, Pm support agent can help to update the new sim card number for you,  you can submit  ticket by direct message:
slusagm
don't buy the sim from PM , it takes long.  Instead, get it from Telus or Koodo or Amazon
after you got the sim card, ask PM to help you to update it
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Yummy
Switch receiving code to email
