07-21-2023 09:40 PM - last edited on 07-22-2023 12:56 AM by computergeek541
no problems texting other numbers local and international - this worked on Koodo,
is this a public mobile limitation or an issue with my setup?
thanks
07-21-2023 10:20 PM
no I've been using 33333* with Koodo and that is on the bus sign - if I use just 33333 (no *) -it works
07-21-2023 10:19 PM
07-21-2023 10:18 PM
07-21-2023 10:18 PM - last edited on 07-31-2023 08:41 PM by Luddite
solved - I was using 33333* which is on the bus stop sign, 33333 works fine,
I had read replies with 33333 meant 33333* - thank you!
[✅ ....... Luddite]
07-21-2023 10:04 PM
I'm using google messages and tried samsung messages, cleared cache, rebooted phone - same error msg, and I have a balance on my account - I can use the translink telephone system but text is more convenient. And I wonder what other short codes might not work - cbc, forest fire.....?
07-21-2023 09:48 PM
33333 is a short code PM supports
we tested ourselves and it worked
But @RudyG had the same issue yesterday, not sure if Rudy got it resolved yet:
https://productioncommunity.publicmobile.ca/t5/Get-Support/translink-33333/m-p/1020799
Since it worked for many of us, it could be just a device issue or temporary network issue
If you are on Android, please start with clear mesaging app cache. And if that does not help, Google Message is a good alternate choice of messaging app
