text messaging not working
Confuzed
I can receive calls but cant send / receive a text
been a customer for month now all was good,  just changed to 3 month subscription, now text sms does not work
7 REPLIES 7
Confuzed
I ve messaged them yesterday  but no reply, are they available by ph number?
@Confuzed
Did you try the SIM card in another working phone?  if you did, did the service work in another phone?
If the service also does not work in another phone, then it is a PM service issues.
I would suggest that you submit a ticket for customer service agent help via the chat bot.
Sushi_Combo
You should get in contact with @CS_Agent for further assistance.
Confuzed
Thanks, just googled how to, done it but still no luck
thanks for your help tho
@Confuzed wrote:
thank you ive rebooted the phone, removed re inserted sim card, no luck
How do i go about a network reset?
thanks
@Confuzed
Which phone do you have? Android versus Apple?
It should be in your phone options settings.
Here is one link from google:
https://www.androidpolice.com/reset-network-settings-android-ios/
Confuzed
thanks
Dunkman
@Confuzed
Maybe try a reboot of your phone.  If that does not work, network reset of phone (note- this will erase any saved wifi passwords).
You can also try your SIM card in another working phone.  This will help determine whether hardware setup issue versus PM service problem.
