text and calls not working after porting number from fido to PM
05-25-2024 11:50 AM
05-25-2024 03:58 PM
It took an hour or so for my phone number to work when I transferred it. My provider sent a text to confirm release. I called my old provider first to ensure they released the number. Also make sure that Fido does not have a lock on your cell phone.
05-25-2024 12:23 PM
@grewalmoni1 In that case submit a ticket at the chat icon bottom right of this page, but if that doesn't work then send support a private message using this link
An agent will reply at the envelope icon top right or, if no envelope, tap your avatar for Messages.
05-25-2024 12:21 PM
i did everything but cant send or recieve calls and texts . we said yes to Fido last night and restarted phone after that
05-25-2024 12:09 PM
It is a common problem with new activations.
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
05-25-2024 11:52 AM - edited 05-25-2024 11:52 AM
@grewalmoni1 Is it both outgoing and incoming, or you can send/call but not receive calls or texts? Did you answer YES to Fido's text and restart your phone with the PM sim in it, and how long ago?
