07-10-2019 09:28 AM - edited 01-05-2022 05:48 AM
I activated Public Mobile for my son yesterday. He is not receiving any texts from me. Also, my calls to him are going straight to voicemail. He is on the $15 plan.
Joining Public
07-14-2019 10:47 AM
@stonechucker wrote:@dianeellsworth, I hope it was an accidental block.
that's what her son told her
07-12-2019 08:15 AM
07-12-2019 06:48 AM
Thank you. I was having the same issue. I restarted my phone and it's working now.
07-12-2019 06:06 AM
Problem fixed. My number was blocked 🙄. Thanks for your help.
07-10-2019 10:03 AM
Will give it a try. Thank you.
07-10-2019 10:02 AM
I had the same issue activating. Just contact moderator: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Provide them with the following information.
Name:
Account number:
Email:
4 digit account pin:
Phone number:
Good luck.
07-10-2019 10:02 AM
@dianeellsworth Ideas:
a) What is make/model of his phone? If iPhone have him turn off iMessages & Facetime then turn on afer a few minutes.
b) Try calling his number again immediately after the first fails. If successful, suggests he has call blocking activated.
c) Have him send you a text and reply directly to it.
07-10-2019 09:57 AM
If you chose a new number, something went wrong with actvatino process. Maybe try re-booting the phone.
Also, try the SIM card in another unlocked phone to determine whether hardware issue versus PM service problem.
If activation issue, likely need to contact moderator.
Send a private message to moderator through the following link :
07-10-2019 09:44 AM
I chose a new number for him???
07-10-2019 09:37 AM - edited 07-10-2019 09:37 AM
@dianeellsworth, did you issue a number port from a different carrier when you activated? Usually an incomplete port results in inability to receive text and calls. That said, if a port was initiated, it should have completed by now.
