11-06-2018 02:13 PM - edited 01-05-2022 06:04 AM
I've have had this phone and PM service for about 6 months - happy customer. Yesterday, after returning from a visit to the US (which I have done nearly every weekend throughout) my phone does not find PM cellular service. What now?
Things I've tried:
restart the phone several times.
change network type from LTE/WCDMA/GSM -> WCDMA/GSM and GSM only. restarting each time.
Neither fix issue.
Is there anythign else I can try?
thanks!
11-07-2018 06:27 PM
Thanks for your reply.
Account Status Active, Balance $0 (paid in full via autopay), next autopay Nov 21, still have 30% data remaining, etc.
removed sim card 2 (not pm), reboot - PM Service!
reinsert sim card 2, reboot - service on both!
THANK YOU!!!
11-07-2018 06:14 PM
What plan do you have? Could it be that your plan has expired ? Check the self service page to confirm you have everything in order. Take out sim #2 and reboot.
11-07-2018 06:00 PM
Would buying a new sim card work?
Can you swap sims w/o having to pay again? I've already autopaid for the month.
11-06-2018 05:40 PM
What else can I do? Am I just out of luck? lol!
11-06-2018 04:27 PM
tried reseating sim card.
no love.
any more ideas would be wonderful.
11-06-2018 03:36 PM
Thanks.
Huawei Mate SE. Very affordable adn convenient for so much travel between US and Canada.
11-06-2018 03:33 PM
Oh, that's a nifty thing. I don't have a suggestion. Having the dual sim shouldn't matter at all.
11-06-2018 03:31 PM
deactivated via Plan & Add Ons / Lost Stolen Phone > Suspend Service
waited 15 min. Resumed service.
Restart phone.
unfortunately that didn't work.
11-06-2018 03:29 PM
correct. its a dual sim phone. I live in NY, work in Canada. my phone allows me to deactivate each sim card independently. When I cross into the US, i deactivate. been working like a charm for 6 months - until now.
11-06-2018 03:07 PM
So, you're not actually using the phone while in the US, it's just with you?
11-06-2018 03:03 PM
Thanks for the reply.
Account active.
I turn my PM sim off shortly after crossing the boarder.
when attempting to connect manually I don't find the network.
11-06-2018 02:24 PM
@divedive, some folks are using the self-serve function of setting your phone to lost for 5-10 minutes, then telling the system it's been found. It seems to re-activate everything for a good number of folks.
11-06-2018 02:16 PM
@divedive, I assume your account is in active status. I have heard of customers who buy US add-ons running into texting issues upon expiry of the US add-on, but nothing as drastic as inability to connect to the network. Anyway, try doing a manual search for the Public Mobile network to see if the phone can connect manually. If the account is active and you cannot manually connect, maybe there is some sort of hardware issue that just reared its ugly head.
