subscribing
Shonra
account stuck at step 6, unable to activate subscription
2 REPLIES 2
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
@Shonra  You need the app to activate not website , are you using the app ? If yes and still the same
send  a  private message   To CS_Agent
