spotty service
adsemail06
not sure how to private message Raluca
my phone shows 4 bars lte service, after attempting to connect it drops to 2 or lower bars on 4g, if the call does go through voice is really spotty at best.  This occurs on exactly the same on 3 phones that I have tried.
Raluca
Customer Service Agent
2 REPLIES 2
Timer
@adsemail06
tried manually select network 3G only or WCDMA only. and rebooting device, and after return back to auto.
check out your area  3G / 4G coverage map
Hi @adsemail06  with PM,  voice is on 3G while data can be on both 3G or LTE.
Look like you have a weak 3G network at your location.  Do you have better connection when you are in different area?
you can try to open a ticket with PM CS agent and they can made aware of the situation , maybe there is ongoing work there
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
