11-27-2024 05:37 PM
Made payment on my subcription today....SMS texting not working.....Can you help ?
11-27-2024 06:10 PM
@rakeshkish @You might just need to reset your network settings , give that a try if you haven’t already and test
11-27-2024 05:44 PM
hi @rakeshkish
voice and data both works and just not sms? you are talking about text from friends or 2FA?
if you have an iPhone, go to iMessage settings to remove the phone number, reboot and enter the phone number again to re-register
11-27-2024 05:39 PM
@rakeshkish try restarting your phone, sometimes this will help. If not contact a support agent
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
