sim pin #
cliffdweller
why is my samsung asking for a sim pin when my iphone says there is no sim pin?
2 REPLIES 2
HI @cliffdweller
is that a new Samsung you just got? it has never been used on PM network?
could be a carrier lock instead.  You need to contact the carrier you got from and ask them for a carrier unlock code
@cliffdweller
it is a different kind of lock
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased|
