sim card
zsp110
Hello,
I have an invalid sim card. Is is possible to activate it again?
Thanks.
If your account was closed more that 90 days, Sim cards can be used only once and you would have to purchase a new SIM.  If you had suspended the account for less than 90 days, it should still be valid and once you sign onto the account their is a section under My profile to change the number.
If it's not working and it's less than 90 days, contact support at the link below to inquire if possible.
zsp110
I previously had an account with a sim card A but I stopped my account for 3 months. Now I get my phone number back with an esim. I want to use my  sim card A. It shows an invalid sim card when I change from esim to the sim card A.  Is is possible to activate sim card A again?
Sansan
Can you clarify what you mean by inactive? Did you previously have an account with Public Mobile and you closed it and are wanting to reopen a new account using the same SIM card?
