01-06-2020 08:33 PM - edited 01-05-2022 08:55 AM
hi guys, can i replace my existing sim card for free? i need NANO sim card and the one I have cannot become smaller by pushing it out of MICRO one. it is old one. since 2011. or do i have to pay 10$ + postage fees? thank you
Phones
01-07-2020 03:07 PM
Thanks
@geopublic wrote:
@gblackma wrote:
@geopublic wrote:@gblackma Sharp scissors should do the trick
Any scissors, or one with a thin blade?
@gblackma Thin blade is better.
01-07-2020 01:25 PM
01-07-2020 11:29 AM
01-07-2020 11:21 AM
01-07-2020 11:18 AM
@popping wrote:0. Check your current SIM card again to remove the Micro-to-Nano adaptor.
1. You can cut a micro SIM into a nano SIM
Here is a tamplate which used to cut SIM card to nano size.
https://dl.dropbox.com/s/0o1f23sztxyxhoo/microsim_template.pdf
1. Print the tamplate in actual size
2. Use double sided tape to tape the template to your SIM card.
3. Cut it along the nano outline.
4. Use a nail file to trim it so that it fits in the SIM card tray.
It is that simple. I had done this procedure 5x without any issues.
2. Buy a new 3-in-1 SIM card for $10 or lower from Amazon or eBay.
3. As @ChuckYeah suggested to ask moderator.
What tool do you use to cut it?
01-06-2020 11:30 PM
@stookie The fact that you've been on PM since 2011 is a good enough case for the mods to credit you for the purchase of a new SIM. Cutting it should do that job and avoid technical issues that initially arise from a new SIM
01-06-2020 09:51 PM
Hey, the best solution to your problem would be to buy a new Public Mobile sim card and then to simply login to you onine account to change your Sim card number.
01-06-2020 09:33 PM
Pour le remplacement de votre carte SIM vous devez commandez une nouvelle carte SIM. Vous devez aussi vous inscrire sur le libre service pour accéder a votre compte. Si vous avez besoin d aide il vous faudra vous inscrire sur la communoté de public mobile et demander de l aidé au modérateur. I am mot a moderator. Je ne suis pas modérateur
01-06-2020 09:16 PM
@stookie Take it to any kiosk and ask them to cut it to the proper size. Most places will do it free of charge.
01-06-2020 09:11 PM
01-06-2020 08:35 PM - edited 01-06-2020 08:36 PM
@stookie I don't believe you can, but ask @CS_Agent .
To contact a moderator, create a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand (e.g. no service, can't send texts, can't call out or no data). Answer Simon's questions until you get here:
@CS_Agent will respond to your concern through the community's private messaging system, usually within 48 hours.
Watch for this indicator of a private message from a moderator.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours: Monday-Friday: 8AM- 12AM EST; Saturday & Sunday: 8AM-10PM EST
